09-26-2006 12:32 PM - edited 03-10-2019 02:46 PM
We have enabled ODBC logging. The Authen_Failure_Code values come across as a numerical value and I am looking for a chart that would have the meaning of those numerical values so that I can have our database supply a verbose value in the field.
09-27-2006 05:23 AM
Cisco TAC gave me the answer I was looking for. ACS only outputs numerical values for this data and the lookup data is refenced in the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco\CiscoAAAv3.2\Dictionaries\000\007
10-03-2006 03:39 AM
That answer was good only for 3.x
From 4.x onwards there is nothing in the registry anymore.
Not sure what they would suggest. Running cssupport with give you a dump of the SQL Anywhere database that includes the same info.... but its VERY cryptic and you'd struggle to find it.
