08-21-2011 04:22 PM - edited 03-10-2019 06:20 PM
Hi everybody
For CCNA security i was testing a lab made of two routers connected by a serial ppp interface and able to reach a Cisco ACS 5.2 AAA Server through a Fast Ethernet 0/0 both.
Now my problem is that using RADIUS i am able to authenticate the ppp connection between the routers but i cannot do the same with TACACS+.
Thinking about a ACS 5.2 configuration issue i also tryed to manipulate the Service Selection Rules in order to direct TACACS+ authorization to Default Network Access insted of Default Device Admin but with no success.
Any help is appreciated, here the routers debug and configs.
Thank you all
debug ppp authentication (from router-A WITH TACACS+)
*Mar 1 02:31:53.295: Se0/0 PPP: Authorization required
*Mar 1 02:31:55.299: Se0/0 CHAP: O CHALLENGE id 231 len 29 from "ciscoACS"
*Mar 1 02:31:55.327: Se0/0 CHAP: I CHALLENGE id 234 len 30 from "ciscoACS2"
*Mar 1 02:31:55.375: Se0/0 CHAP: Using hostname from interface CHAP
*Mar 1 02:31:55.375: Se0/0 CHAP: Using password from interface CHAP
*Mar 1 02:31:55.379: Se0/0 CHAP: O RESPONSE id 234 len 29 from "ciscoACS"
*Mar 1 02:31:55.383: Se0/0 CHAP: I RESPONSE id 231 len 30 from "ciscoACS2"
*Mar 1 02:31:55.403: Se0/0 PPP: Sent CHAP LOGIN Request
*Mar 1 02:31:55.455: Se0/0 PPP: Received LOGIN Response FAIL
*Mar 1 02:31:55.459: Se0/0 CHAP: O FAILURE id 231 len 25 msg is "Authentication failed"
debug ppp authentication (from router-B WITH TACACS+)
*Mar 1 02:28:53.347: Se0/0 PPP: Authorization required
*Mar 1 02:28:53.383: Se0/0 CHAP: O CHALLENGE id 184 len 30 from "ciscoACS2"
*Mar 1 02:28:53.391: Se0/0 CHAP: I CHALLENGE id 181 len 29 from "ciscoACS"
*Mar 1 02:28:53.455: Se0/0 CHAP: Using hostname from interface CHAP
*Mar 1 02:28:53.455: Se0/0 CHAP: Using password from interface CHAP
*Mar 1 02:28:53.459: Se0/0 CHAP: O RESPONSE id 181 len 30 from "ciscoACS2"
*Mar 1 02:28:53.463: Se0/0 CHAP: I RESPONSE id 184 len 29 from "ciscoACS"
*Mar 1 02:28:53.483: Se0/0 PPP: Sent CHAP LOGIN Request
*Mar 1 02:28:53.535: Se0/0 PPP: Received LOGIN Response FAIL
*Mar 1 02:28:53.543: Se0/0 CHAP: O FAILURE id 184 len 25 msg is "Authentication failed"
Router-A configuration (with TACACS+ for PPP -> NOT WORKING)
version 12.4
hostname Router-A
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication ppp ACS_PPP_AUTHENTICATION group tacacs+
aaa authorization network ACS_NET_AUTHORIZATION group tacacs+
aaa session-id common
resource policy
memory-size iomem 5
ip cef
interface FastEthernet0/0
ip address 172.16.1.3 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 10.0.0.1 255.255.255.254
encapsulation ppp
clock rate 2000000
ppp authentication chap ACS_PPP_AUTHENTICATION
ppp authorization ACS_NET_AUTHORIZATION
ppp chap hostname ciscoACS
ppp chap password 0 ciscoACS
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
no ip http secure-server
tacacs-server host 172.16.1.254 key ciscoACS
tacacs-server directed-request
radius-server host 172.16.1.254 auth-port 1645 acct-port 1646 key ciscoACS
control-plane
line con 0
line aux 0
line vty 0 4
end
Router-B configuration (with TACACS+ for PPP -> NOT WORKING)
version 12.4
hostname Router-B
boot-start-marker
boot-end-marker
aaa new-model
resource policy
memory-size iomem 5
ip cef
ip address 172.16.1.4 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 10.0.0.2 255.255.255.254
encapsulation ppp
clock rate 2000000
ppp chap hostname ciscoACS2
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
Router-A configuration (with RAIDUS for PPP -> WORKING)
version 12.4
hostname Router-A
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication ppp ACS_PPP_AUTHENTICATION group radius
aaa authorization network ACS_NET_AUTHORIZATION group radius
resource policy
memory-size iomem 5
ip cef
duplex auto
speed auto
interface Serial0/0
encapsulation ppp
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
Router-B configuration (with RADIUS for PPP -> WORKING)
version 12.4
hostname Router-B
boot-start-marker
boot-end-marker
aaa new-model
resource policy
memory-size iomem 5
ip cef
duplex auto
speed auto
interface Serial0/0
encapsulation ppp
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
08-22-2011 04:49 PM
Ok, Ok i admit it was my fault to not use that common and sometimes strangely new feature probably older than me called "SEARCH"
I checked another discussion regarding the same subject and it turned out by their knowledge that ACS 5.x manage
Any other way doesn't work...any other opinion? ( i just can't help the fact that Cisco doesn't let use TACACS+ for PPP Authentication...does anybody knows why?)
08-22-2011 06:20 PM
UPDATE: I was able to authenticate with ppp and chap with another shareware server...is it sure that Cisco ACS doesn't allow this completely???
