Problem importing endpoints from CSV file ISE 2.0
Ole J
Hi Guys,
I have an ISE 2.0.0.306 with pach 3 running.
I’m trying to import a long list of endpoints into a group that I have created under Endpoint Identity Groups. But the problem is that the “Endpoint Identity Group” is not imported.
I have created an endpoint manually, and manually moved it to the group that I have created. After that I exported the endpoint to CSV file and opened the file, the group is missing.
I have tried with different group names like “citrix” and “test” with no luck.
I have old groups that I created before upgrading to 2.0 that I can import to/from.
Can someone help me?
Thanks for all the help in advance.
0 Replies 0
