RDP is not working with Cisco NAM (User and Machine Auth)
oleg_kobzar
RDP to Windows 10  machine is not working when Cisco NAM is used instead native Windows supplicant. The case is below:
1) PC is turned on and passed machine authentication
2) RDP is initiated to PC and user authentication passed. But RDP is not established.Windows Firewall blocks this traffic, even if  there is a permit rule in its configuration (tcp/udp from any source  to port 3389)
3) Machine authentication is passed again.
User and Machine VLAN are the same. It works only if user is locally login into PC( user authentication on switch port) or if Windows Firewall is disabled. Logs are below.
2018-03-30 16:08:52 DROP TCP 172.27.235.51 172.27.235.53 51817 3389 0 - 0 0 0 - - - RECEIVE
2018-03-30 16:08:52 DROP UDP 172.27.235.51 172.27.235.53 62652 3389 0 - - - - - - - RECEIVE
Does anyone use such deployment of 802.1x with Cisco NAM?
DHaya
Its known bug,
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo47467
Work around as below.
1. In Registry Editor, locate the following registry subkey:
HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy
2. Right-click the Parameters registry subkey, point to New, and then click DWORD (32-bit) Value.
3. Rename the new registry entry to IntfQuarantineEnabled and set the value to 0.
Hope this helps
Hi Octavian,
Thanks a lot for your reply.
But could you please specify why it is not working. I tried to check the configuration guide but changing registry key EnforceSingleLogon didn`t help.
Is it possible to modify anything to have working RDP for this case?
I hope you will answer and show the the direction because at this moment neither Cisco or MS can help me.
Hi Oleg,
Please check if windows firewall is completely off just to exclude this as a possible issue.
Also, make sure you've added the correct dword in registry to allow RDP with a different user than the currently logged in user.
I've tested this in the past and it worked.
Octavian
DHaya
Its known bug,
Hope this helps
