09-12-2008 05:49 AM - edited 03-10-2019 04:05 PM
Hello.
We have a Secure ACS 4.1 Solution Engine. I would like to use the Remote Agent CLI to export users but I don't understand how (or where) to launch the Remote Agent CLI. Does it run from one of our Remote Agent workstations?
Any help would be greatly appreciated.
09-12-2008 05:55 AM
You cannot do that using Remote Agent.
May I ask what do you ultimately want to achieve by exporting users from ACS 4.1, and what is your impression that what will you have in that exported user's ?
Prem
Please rate if it helps!
09-12-2008 06:00 AM
The Troubleshooting Guide mentions a Remote Agent CLI (Solution Engine). One of the CLI commands can be used to export user info to an FTP server.
Goal: I need to have a list of all users on the ACS.
09-12-2008 06:03 AM
You can do that from serial console,
"exportusers"
Prem
09-12-2008 06:09 AM
The device is at a remote site. From the documentation, it appears that this can be done remotely. Is this not possible?
09-12-2008 06:12 AM
Which documentation are you referring to ?
AFAIK, we need serial console access for ACS SE to get this done.
Prem
