Secure ACS - Remote Agent CLI
sometechguy
Hello.
We have a Secure ACS 4.1 Solution Engine. I would like to use the Remote Agent CLI to export users but I don't understand how (or where) to launch the Remote Agent CLI. Does it run from one of our Remote Agent workstations?
Any help would be greatly appreciated.
5 Replies 5
Premdeep Banga
Level 7
Level 7
You cannot do that using Remote Agent.
May I ask what do you ultimately want to achieve by exporting users from ACS 4.1, and what is your impression that what will you have in that exported user's ?
Prem
Please rate if it helps!
The Troubleshooting Guide mentions a Remote Agent CLI (Solution Engine). One of the CLI commands can be used to export user info to an FTP server.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1.3/troubleshooting/guide/Ch1.html#wp1041669
Goal: I need to have a list of all users on the ACS.
The device is at a remote site. From the documentation, it appears that this can be done remotely. Is this not possible?
Which documentation are you referring to ?
AFAIK, we need serial console access for ACS SE to get this done.
Prem
