Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
290
Highlighted
Beginner
Setting up Dot1x with ACS5.2
Help! I've been trying to setup and  test Dot1x and can't seem to get it working.
I have an:
ACS5.2
Catalyst 2950
Win 7 Client
I think everything is configured as it should be with the Switch and ACS but not sure if I have done the Win 7 Client correct.
In the ACS logs I can see the Authentication request come in but it fails with message 'Misconfigured EAP on ACS or Network Device'. Now I don't want to use Certificates so I set the Win 7 Client to use Microsoft PEAP in the 802.1x auth settings:
The logs in ACS show the username I use but the Authentication type says it's trying to use EAP-TLS, is that right?
How can I get this working?
Stuart
Everyone's tags (4)
