08-06-2019 08:51 PM
Hi everyone,
We have a wired dot1x authentication problem here.
I'm sure the NPS server is ok,because other clients are using it.
We using a switch C2960L running version 15.2(5c)E
Here are my conf:
interface GigabitEthernet0/13
description dot1x-fail
switchport access vlan 82
switchport mode access
authentication event server dead action authorize vlan 82
authentication event no-response action authorize vlan 82
authentication event server alive action reinitialize
authentication host-mode multi-auth
authentication port-control auto
authentication violation restrict
dot1x pae authenticator
dot1x timeout quiet-period 5
dot1x timeout tx-period 5
dot1x timeout supp-timeout 5
spanning-tree portfast edge
end
Client had authenticated fail
#sho authentication sessions interface gigabitEthernet 0/13 detail
Interface: GigabitEthernet0/13
MAC Address: d89e.f322.f1ce
IPv6 Address: Unknown
IPv4 Address: 10.80.82.20
User-Name: host/PC
Status: Authorized
Domain: DATA
Oper host mode: multi-auth
Oper control dir: both
Session timeout: N/A
Restart timeout: N/A
Session Uptime: 84s
Common Session ID: 0000000000000027C930368D
Acct Session ID: Unknown
Handle: 0xB3000015
Current Policy: POLICY_Gi0/13
Local Policies:
Service Template: GUEST_SUPP_VLAN_Gi0/13 (priority 150)
Vlan Group: Vlan: 82
Method status list:
Method State
dot1x Stopped
#sho dot1x interface gigabitEthernet 0/13 detail
Dot1x Info for GigabitEthernet0/13
PAE = AUTHENTICATOR
QuietPeriod = 5
ServerTimeout = 0
SuppTimeout = 5
ReAuthMax = 2
MaxReq = 2
TxPeriod = 5
Dot1x Authenticator Client List Empty
Interface Identifier Method Domain Status Fg Session ID
Gi0/13 d89e.f322.f1ce N/A DATA Auth 0000000000000027C930368D
I have tried to debug dot1x all. Here are the debug output:
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Interface state changed to UP
Aug 7 11:28:15: dot1x-ev:DOT1X Supplicant not enabled on GigabitEthernet0/13
Aug 7 11:28:15: dot1x-packet:[d89e.f322.f1ce, Gi0/13] queuing an EAPOL pkt on Auth Q
Aug 7 11:28:15: dot1x-packet:EAPOL pak rx - Ver: 0x1 type: 0x1
Aug 7 11:28:15: dot1x-packet: length: 0x0000
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Dequeued pkt: Int Gi0/13 CODE= 0,TYPE= 0,LEN= 0
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Received pkt saddr =d89e.f322.f1ce , daddr = 0180.c200.0003, pae-ether-type = 888e.0101.0000
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Couldn't find the supplicant in the list
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] New client detected, sending session start event for d89e.f322.f1ce
Aug 7 11:28:15: dot1x_auth Gi0/13: initial state auth_initialize has enter
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010: initialising
Aug 7 11:28:15: dot1x_auth Gi0/13: during state auth_initialize, got event 0(cfg_auto)
Aug 7 11:28:15: @@@ dot1x_auth Gi0/13: auth_initialize -> auth_disconnected
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010: disconnected
Aug 7 11:28:15: dot1x_auth Gi0/13: idle during state auth_disconnected
Aug 7 11:28:15: @@@ dot1x_auth Gi0/13: auth_disconnected -> auth_restart
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010: entering restart
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending create new context event to EAP for 0xAA000010 (d89e.f322.f1ce)
Aug 7 11:28:15: dot1x_auth_bend Gi0/13: initial state auth_bend_initialize has enter
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010: entering init state
Aug 7 11:28:15: dot1x_auth_bend Gi0/13: initial state auth_bend_initialize has idle
Aug 7 11:28:15: dot1x_auth_bend Gi0/13: during state auth_bend_initialize, got event 16383(idle)
Aug 7 11:28:15: @@@ dot1x_auth_bend Gi0/13: auth_bend_initialize -> auth_bend_idle
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering idle state
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Created a client entry (0xAA000010)
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Dot1x authentication started for 0xAA000010 (d89e.f322.f1ce)
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting !EAP_RESTART on Client 0xAA000010
Aug 7 11:28:15: dot1x_auth Gi0/13: during state auth_restart, got event 6(no_eapRestart)
Aug 7 11:28:15: @@@ dot1x_auth Gi0/13: auth_restart -> auth_connecting
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:enter connecting state
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010: restart connecting
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting RX_REQ on Client 0xAA000010
Aug 7 11:28:15: dot1x_auth Gi0/13: during state auth_connecting, got event 10(eapReq_no_reAuthMax)
Aug 7 11:28:15: @@@ dot1x_auth Gi0/13: auth_connecting -> auth_authenticating
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010: authenticating state entered
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:connecting authenticating action
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting AUTH_START for 0xAA000010
Aug 7 11:28:15: dot1x_auth_bend Gi0/13: during state auth_bend_idle, got event 4(eapReq_authStart)
Aug 7 11:28:15: @@@ dot1x_auth_bend Gi0/13: auth_bend_idle -> auth_bend_request
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering request state
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending EAPOL packet
Aug 7 11:28:15: dot1x-registry:registry:dot1x_ether_macaddr called
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending out EAPOL packet to MAC d89e.f322.f1ce
Aug 7 11:28:15: dot1x-packet:EAPOL pak Tx - Ver: 0x3 type: 0x0
Aug 7 11:28:15: dot1x-packet: length: 0x0005
Aug 7 11:28:15: dot1x-packet:EAP code: 0x1 id: 0x1 length: 0x0005
Aug 7 11:28:15: dot1x-packet: type: 0x1
Aug 7 11:28:15: dot1x-packet:[d89e.f322.f1ce, Gi0/13] EAPOL packet sent to client 0xAA000010
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:idle request action
Aug 7 11:28:15: dot1x-packet:[d89e.f322.f1ce, Gi0/13] Queuing an EAPOL pkt on Authenticator Q
Aug 7 11:28:15: dot1x-packet:EAPOL pak rx - Ver: 0x1 type: 0x0
Aug 7 11:28:15: dot1x-packet: length: 0x002F
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Dequeued pkt: Int Gi0/13 CODE= 2,TYPE= 1,LEN= 47
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Received pkt saddr =d89e.f322.f1ce , daddr = 0180.c200.0003, pae-ether-type = 888e.0100.002f
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting EAPOL_EAP for 0xAA000010
Aug 7 11:28:15: dot1x_auth_bend Gi0/13: during state auth_bend_request, got event 6(eapolEap)
Aug 7 11:28:15: @@@ dot1x_auth_bend Gi0/13: auth_bend_request -> auth_bend_response
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering response state
Aug 7 11:28:15: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Response sent to the server from 0xAA000010
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:request response action
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting EAP_REQ for 0xAA000010
Aug 7 11:28:15: dot1x_auth_bend Gi0/13: during state auth_bend_response, got event 7(eapReq)
Aug 7 11:28:15: @@@ dot1x_auth_bend Gi0/13: auth_bend_response -> auth_bend_request
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:exiting response state
Aug 7 11:28:15: dot1x-packet: length: 0x0006
Aug 7 11:28:15: dot1x-packet:EAP code: 0x1 id: 0x2 length: 0x0006
Aug 7 11:28:15: dot1x-packet: type: 0xD
Aug 7 11:28:15: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:response request action
Aug 7 11:28:15: dot1x-packet: length: 0x006D
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Dequeued pkt: Int Gi0/13 CODE= 2,TYPE= 13,LEN= 109
Aug 7 11:28:15: dot1x-ev:[Gi0/13] Received pkt saddr =d89e.f322.f1ce , daddr = 0180.c200.0003, pae-ether-type = 888e.0100.006d
Aug 7 11:28:15: dot1x-packet: length: 0x05EE
Aug 7 11:28:15: dot1x-packet:EAP code: 0x1 id: 0x3 length: 0x05EE
Aug 7 11:28:17: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Aug 7 11:28:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Aug 7 11:28:20: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting EAP_REQ for 0xAA000010
Aug 7 11:28:20: dot1x_auth_bend Gi0/13: during state auth_bend_request, got event 7(eapReq)
Aug 7 11:28:20: @@@ dot1x_auth_bend Gi0/13: auth_bend_request -> auth_bend_request
Aug 7 11:28:20: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:request request action
Aug 7 11:28:20: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering request state
Aug 7 11:28:20: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending EAPOL packet
Aug 7 11:28:20: dot1x-registry:registry:dot1x_ether_macaddr called
Aug 7 11:28:20: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending out EAPOL packet to MAC d89e.f322.f1ce
Aug 7 11:28:20: dot1x-packet:EAPOL pak Tx - Ver: 0x3 type: 0x0
Aug 7 11:28:20: dot1x-packet: length: 0x05EE
Aug 7 11:28:20: dot1x-packet:EAP code: 0x1 id: 0x3 length: 0x05EE
Aug 7 11:28:20: dot1x-packet: type: 0xD
Aug 7 11:28:20: dot1x-packet:[d89e.f322.f1ce, Gi0/13] EAPOL packet sent to client 0xAA000010
Aug 7 11:28:25: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting EAP_REQ for 0xAA000010
Aug 7 11:28:25: dot1x_auth_bend Gi0/13: during state auth_bend_request, got event 7(eapReq)
Aug 7 11:28:25: @@@ dot1x_auth_bend Gi0/13: auth_bend_request -> auth_bend_request
Aug 7 11:28:25: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:request request action
Aug 7 11:28:25: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering request state
Aug 7 11:28:25: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending EAPOL packet
Aug 7 11:28:25: dot1x-registry:registry:dot1x_ether_macaddr called
Aug 7 11:28:25: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending out EAPOL packet to MAC d89e.f322.f1ce
Aug 7 11:28:25: dot1x-packet:EAPOL pak Tx - Ver: 0x3 type: 0x0
Aug 7 11:28:25: dot1x-packet: length: 0x05EE
Aug 7 11:28:25: dot1x-packet:EAP code: 0x1 id: 0x3 length: 0x05EE
Aug 7 11:28:25: dot1x-packet: type: 0xD
Aug 7 11:28:25: dot1x-packet:[d89e.f322.f1ce, Gi0/13] EAPOL packet sent to client 0xAA000010
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Received an EAP Timeout
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting EAP_TIMEOUT for 0xAA000010
Aug 7 11:28:30: dot1x_auth_bend Gi0/13: during state auth_bend_request, got event 12(eapTimeout)
Aug 7 11:28:30: @@@ dot1x_auth_bend Gi0/13: auth_bend_request -> auth_bend_timeout
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering timeout state
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:request timeout action
Aug 7 11:28:30: dot1x_auth_bend Gi0/13: idle during state auth_bend_timeout
Aug 7 11:28:30: @@@ dot1x_auth_bend Gi0/13: auth_bend_timeout -> auth_bend_idle
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering idle state
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] Posting AUTH_TIMEOUT on Client 0xAA000010
Aug 7 11:28:30: dot1x_auth Gi0/13: during state auth_authenticating, got event 14(authTimeout)
Aug 7 11:28:30: @@@ dot1x_auth Gi0/13: auth_authenticating -> auth_authc_result
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:exiting authenticating state
Aug 7 11:28:30: dot1x-sm:[d89e.f322.f1ce, Gi0/13] 0xAA000010:entering authc result state
Aug 7 11:28:30: %DOT1X-5-FAIL: Authentication failed for client (d89e.f322.f1ce) on Interface Gi0/13 AuditSessionID 0000000000000023C9218FF3
Aug 7 11:28:30: dot1x-packet:[d89e.f322.f1ce, Gi0/13] Added username in dot1x
Aug 7 11:28:30: dot1x-packet:[d89e.f322.f1ce, Gi0/13] Dot1x did not receive any key data
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Processing client delete for hdl 0xAA000010 sent by Auth Mgr
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] d89e.f322.f1ce: sending canned failure due to method termination
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending EAPOL packet
Aug 7 11:28:30: dot1x-registry:registry:dot1x_ether_macaddr called
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Sending out EAPOL packet to MAC d89e.f322.f1ce
Aug 7 11:28:30: dot1x-packet:EAPOL pak Tx - Ver: 0x3 type: 0x0
Aug 7 11:28:30: dot1x-packet: length: 0x0004
Aug 7 11:28:30: dot1x-packet:EAP code: 0x4 id: 0x3 length: 0x0004
Aug 7 11:28:30: dot1x-packet:[d89e.f322.f1ce, Gi0/13] EAPOL canned status packet sent to client 0xAA000010
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Deleting client 0xAA000010 (d89e.f322.f1ce)
Aug 7 11:28:30: dot1x-ev:[d89e.f322.f1ce, Gi0/13] Delete auth client (0xAA000010) message
Aug 7 11:28:30: dot1x-ev:Auth client ctx destroyed
Any idea's or help will be appreciated.
Thank you
Tim
08-07-2019 07:15 AM
In general it is much easier to see the overall issue on the policy server. Can you validate what NPS is sending back to the switch? I suggest stripping the policy down to bare minimum and send back ACCESS-ACCEPT only and start adding additional attributes once successful.
07-27-2020 08:27 AM
Hi Guys
any idea ? We have the same issue. One i have allready figured out is. There seems to be a problem with how fast the port comes up. For test proposals we remove the spanning-tree portfast edge. After we did that the authentication works fine. Any idea what the spanning- tree portfast makes with dot1x ???? Very strange ….
12-15-2021 01:47 AM
We are witnessing exactly the same. After removing spanning-tree portfast edge dot1x works fine. With portfast configuration authentication fails after "Dot1x did not receive any key data". I don't have any explanation for this behavior.
Did you find anything out about the reason for this?
