Unable to Authenticate Check Point (GAIA R76) and ACS 5.2 using TACACS+
rodmunch999
We are trying to authenticate a Check Point Firewall(GAIA R76) to a 5.2 ACS using TACACS+
We are able to authenticate the user OK but when we do a  'tacacs_enable TACP-15' to get elevated privileges the session hangs and gives 'internal error' message.
On the ACS the shell profile is set for Privilige 15 (The Check Point) manual says that no other TACACS+ attributes need to be applied.
On the Check Point we have installed SecurePlatform_HOTFIX_GIZMO_HF_BASE_389 which contains a rolled-up set of TACACS patches. Also we have been able to get this working with the IPSO Check Point's so this seems to be specific to GAIA's
Has anyone managed to get this working ?
0 Replies 0
