Using Internal and External Identity stores at the same time
nsoftic
Can I use Internal Identity store and external Identity store at the same time in ACS 5.5.
I want to give access to a specific group of people to a specific service, but I would like to integrate with their Active Directory credentials.
How do I do this?
Nedim
Saurav Lodh
Level 7
Level 7
>> you can use identity store sequence
Configuring Identity Store Sequences
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-1/user/guide/acsuserguide/users_id_stores.html#wp1054132
using Identity store sequence you can define the order of identity stores in which you can to check for credentials
