wireless users authenticate with acs 4.2.1 & oracle9i failed
weiyong wu
wireless users authenticate with acs 4.2.1 & oracle9i failed,i don't know how to configure acs and oracle.
acs can connect oracle's odbc,but wireless user cannot authenticate successfully through the oracle's data, who can help me solve this problem
Jatin Katyal
What error are you getting on ACS 4.2.1.15 > reports and activities > failed attempt?
What are the end clients being used in your setup for authentication, windows 7? What eap method are we using peap or eap-tls?
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
kcnajaf
Level 7
Level 7
I'm hoping that your trying to authenticate users from orace database? Is in it?
This is supported only for windows version of ACS. Please go through below link and look under heading "ODBC Database (ACS for Windows Only)"
Hope that helps
Najaf
Please rate when applicable or helpful !!!
Are you getting any logs under ACS > reports and activities > failed attempt?
What windows supplicant and eap method are you using?
~BR
Jatin Katyal
~Jatin
