WLC MAB with airespace interface
Eric Marshott
We have ISE 2.2 with WLC's running 8.2 and WLAN running mab.
I want to put certain devices connecting to this WLAN (using identity group/mac-address) into certain WLAN interface.
I have tried using Airespace:Airespace-Interface-Name = <name of interface on WLC> and ACCESS_ACCEPT.
It seems the WLC is not accepting the airespace interface name AV pair, and it is taking only the ACCESS_ACCEPT.
Does this mean that WLC with WLAN running mab does not support CoA?
Is there a workaround or other solution to this?
Thank you kindly
-Eric M
Hi @Eric Marshott
WLC will support the change of authorization through Radius.
Instead of interface name use the VLAN ID on the policy results. It will work. Make sure that AAA Override is enabled on the controller.
Refer : Dynamic VLAN Assignment Through ISE
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
