Beginner
WLC Monitor and LobbyAdmin access on ISE
Hello
I am configuring WLC access thru ISE. I see some options
If I select 'Monitor', the raw view is role1=MONITOR, similarly Lobby's raw view is... role1=Lobby
I have a requirement, the end user should have both the rules, how is this possible?
Can I do something like, add role1 and role2 in views as Monitor and Lobby?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: WLC Monitor and LobbyAdmin access on ISE
It looks mutually exclusive so you would need separate accounts for them.
Configuring TACACS+ on the ACS mentioned,
Note
You should not combine the MONITOR role or the LOBBY role with any other roles. If you specify one of these two roles in the Custom Attributes text box, users will have MONITOR or LOBBY privileges only, even if additional roles are specified.
2 REPLIES 2
Note
Beginner
Thank you.
