Duo for Outlook Web App (OWA) no more Working with Exchange SE
Danny Gheraille
Since migrating from Exchange 2019 to Exchange Server, DUO for OWA is no longer working.
I get this error when I try to reinstall it?
I have the correct .Net Version on IIS :
 Unable to uninstall the current version (nothing happens)
Any idea who to fix this ?
Danny
Danny Gheraille
Fixed by :
  • uninstalling DUO via msiexec in command prompt
  • reinstalling DUO via msiexec in command prompt
DuoKristina
Thanks for sharing your solution @Danny Gheraille .
To understand the initial issue better, was it that you...
1. Had Duo for OWA installed on Exchange 2019 (which version of the Duo OWA app?)
2. Performed an in-place upgrade from Ex2019 CU 14 or 15 to Exchange SE (as described in https://techcommunity.microsoft.com/blog/exchange/upgrading-your-organization-from-current-versions-to-exchange-server-se/4241305) without uninstalling Duo first?
We do recommend uninstalling Duo before applying an Exchange CU https://help.duo.com/s/article/1074, but it is interesting the GUI installer did not work for you.
Duo, not DUO.
