Fortigate vpn integration with duo
Vishal6
Level 5
Level 5
Hi All,
Need Fortinet’s SAML integration with Duo as an identity provider, using Azure AD as the directory source. Do i require authentication proxy to install in AD source ?. Im folllowing below article to do the configuration.
https://community.fortinet.com/t5/FortiGate/Technical-Tip-SSL-VPN-with-DUO-as-SAML-IdP-using-Azure-AD-as/ta-p/230378
DuoKristina
Duo SSO has three ways to authenticate your users:
1. Duo as the identity store (FortiGate > Duo SSO > Duo verifies primary creds for users directly in Duo without connecting to another directory).
2. Active Directory as the identity store (FortiGate > Duo SSO > Duo Authentication Proxy (LDAP) > Active Directory > AD DC verifies primary creds).
3. Entra ID (Azure AD) as the identity store (FortiGate > Duo SSO > Entra ID (SAML) > Entra ID verifies primary creds).
Only #2 needs you to install Duo Authentication Proxy.
Have you read through https://duo.com/docs/sso#external-authentication-sources? It explains external authentication options for Duo SSO.
Duo, not DUO.
