Linux ssh pam and KbdInteractive
Tamerlane
I have set up duo for unix on several ubuntu 20, 22 and 24 machines.
On all machines, the "pamtester -v ssh myname authenticate" command triggers a push, then follows up with prompt for password (as expected.)
On some machines, ssh only requires a password.   I can't figure out what is different.
On problem machines I have tried to explicitly set the correct ssh settings, or various combos.
# cat /etc/ssh/sshd_config.d/1-sshd-duo.conf
KbdInteractiveAuthentication yes
UseDNS no
UsePAM yes
PasswordAuthentication no
ChallengeResponseAuthentication yes
I think the first 3 are must have .   Not sure about the last 2.
Any thoughts ?
balaji.bandi
Check the below document, explain based on the requirement what needs to be configured :
https://duo.com/docs/duounix#pam-configuration
BB
Tamerlane
Turns out there was a typo.
I had a working /etc/pam.d/sshd config.  I created a script to copy that and other pam.d files to other machines.  But I had a typo in the script that copied /etc/pam.d/sshd to /etc/pam.d/ssh.   "pamtester ssh" verifies the ssh file is valid even tho it was for a non-existent service.  Moving /etc/pam.d/ssh to /etc/pam.d/sshd fixed the issue.
DuoKristina
@Tamerlane Glad you identified the issue! If it isn't too much trouble would you mind marking this as solved?
Duo, not DUO.
