Setup DUO MFA on an Oracle Cloud Infrastructure VM
Stephen_Keating
I have a VM in the Oracle Cloud Infrastructure FedRamp cloud, and need the procedure to install/configure DUO MFA. Oracle says they have no procedure and to contact DUO. Is there anything special I need to do to do an install in the FedRamp cloud?
timshores1
Hi @Stephen_Keating thanks for asking.
First, it depends on your edition. If you’re using Duo Federal edition, please review this guide:
If you’re using Duo MFA, Access or Beyond edition, could you tell me what Duo product or feature you need to install? Or what applications you need to protect in your VM? I can point you to the documentation that will help.
