Unable to use MFA with FortiGate SSLVPN
eber1233
I am trying to set up a FortiGate SSL VPN application and was able to sync my Azure directory including the User Group needed to access Duo.
After configuring the proxy on the RADIUS Server, and on the FortiGate itself using RADIUS server, I attempted to connect but the message I get through FortiClient is VPN Unreachable.
I checked the Duo Global policy and as a test, under Authentication Policy. I selected bypass 2FA. After doing so, I tested the FortiClient connection and it went through no problem.
Was wondering if anyone else had a similar issue?
eber1233
Resolved. had to create a username alias in order to authenticate.
eber1233
Glad you figured it out, @eber1233 .
Duo, not DUO.
