08-29-2022 11:26 PM
we would like to know, what type of hardware tokens are working with Duo MacLogon 2.0.0. The documerntation notes “OTP Hardware Tokens”, but what are those exactly? E.g., can a Yubikey made to work with MacLogon 2.0.0?
Solved! Go to Solution.
08-30-2022 06:48 AM
Yes, if you have a Yubikey that supports OTP generation, like a Yubikey 5, it can be used to generate OTPs for Duo applications like Duo Unix, Duo for Windows Logon, Duo for macOS, Duo SSO, etc.
A Duo admin needs to import the Yubikey information into the Duo Admin Panel and then assign that imported hardware token to a user.
More info about the OTP hardware token import process here: https://duo.com/docs/administration-devices#managing-otp-hardware-tokens
More info about Yubikeys + Duo here: Duo Administration - Configuring YubiKeys for OTP use with Duo | Duo Security
08-30-2022 06:48 AM
08-31-2022 06:48 AM
Thanks @DuoKristina - I will get some Yubikey 5s and check that out.
09-01-2022 12:50 AM
One quick follow-up question… the setting for skipping Duo MacLogon when a smartcard is inserted would still be left to “false”?
Thanks, Stephan
09-01-2022 11:55 AM
Yes, if the intent is to use the Yubikey as an token for Duo and not instead of Duo auth.
09-01-2022 12:55 PM
Just for the sake of completeness… the old Yubikey 4s do also work just fine and the setup is really easy.
