10-20-2017 01:02 PM - edited 03-21-2019 10:57 AM
This should be pretty simple.
I have created 2 VLAN's on the Cisco 892FSP router. VLAN104 and VLAN110.
I have ports 0-3 assigned to VLAN104 and ports 4-7 assigned to VLAN110.
I would like any device on VLAN104 to communicate with any device on VLAN110.
What is the best solution?
Thank You
10-21-2017 07:44 AM
Hi @cassidymf
Currently you are not able to ping between vlans?
Can you share show running config command?
-If I helped you somehow, please, rate it as useful.-
02-26-2019 01:44 AM
i have created VLAN on my (Cisco 892 SFP) Vlan 1 on port 0 to 3. Vlan 2 on port 4,5. Vlan 3 on port 6,7.
vlan 1 IP : 192.168.1.1
vlan 2 IP : 192.168.2.1
vlan 3 IP : 192.168.3.1
once i connect PC to Vlan 1 and its get IP 192.168.1.100 on the other hand I connect PC to vlan 3 and get IP 192.168.3.100 (that's OK) but both devices are able to ping to each other and can do remote access to each other, it suppose to be not communicate to each other.
i did all vlans ip nat inside.
can you help me please in this regard.
