05-08-2023 08:29 AM
Hey team
So, i have a question about the Cisco ISR1000 or C1000 equipment.
Some say that they support 2 WAN ports and 8 LAN ports. My question is, if I have a another WAN link, can I use any of these LAN ports? Does anyone have any ideas... or is it only limited to 2 WANs per device? 2 WAN ports is that's all ?
Solved! Go to Solution.
05-08-2023 08:56 AM - edited 05-08-2023 08:56 AM
Hello @wmendozaOpenlink,
As concerned the use of LAN ports for WAN connectivity, it's unlikely that you can directly utilize the LAN ports for WAN connections without additional hardware or configuration changes. The LAN ports on these routers are typically intended for local network connectivity, such as connecting to local devices or switches. WAN connections usually require specialized interfaces, such as Ethernet WAN ports or specific WAN modules.
05-08-2023 11:09 PM
1 wired WAN port + 1 x 4G/5G modem.
