Cisco RV110W
lbogoyski
Hello all
I have the following question: I have 3 CISCO rv110w router. One of them is the most important for me is at my warehouse. The other two are in my shop. I want to make  first router(in warehouse) to  vpn server, and the other two to be his vpn clients. Can you explain in detail how to do this.
Thanks in advance
jeffrrod
Level 4
Level 4
Dear Lubo,
Thank you for reaching Small Business Support Community.
Please refer to the below document for a 'VPN client" configuration on RV110W routers;
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2501
For a more detail step by step procedure, refer to the admin guide, p.96;
http://www.cisco.com/en/US/docs/routers/csbr/rv110w/administration/guide/rv110w_admin.pdf
I hope you find this information useful and please let us know if there is any further assistance we may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
jeffrrod
Level 4
Level 4
Dear Lubo,
Kind regards,
lbogoyski
Hello Mr Jefferey Rodrigez Sequra
Thank you for a fast replay.
Your information helped me to achieve a good result. Thank you
Best regards
