Cisco RV120w VPN tunnel problem
d.herremans
I gave setup a vpn gateway between two cisco RV120W. The connection is established.
Active IPsec Security Association Table
Policy NameEndpointPacketsKBytesStateAction
RxTxRxTx
VPN-INTERDIO87.65.38.62000.000.00IPsec SA Established
Poll Interval:
(Seconds)
The problem is that there is no trafic. Even ping te remote internal nework is not working. For testing i have disabeld at both sites te firewall and have configured both with an access rule any to any.
Default Outbound Policy
Policy:
Allow
Block
Access Rule Table
ActionServiceStatus
Connection Type
Source IPDestination IP
Always AllowANYEnabledInbound (WAN (Internet) > LAN (Local Network))Any
1 - 1 of 1
Can anywone tel me wat i am missing in this configuration.
Wan 1: 94.224.5.118
IP internal 1: 192.9.212.1
Wan 2: 87.65.38.62
IP internal 2: 192.168.212.1
Danny
jonatrod
Level 7
Level 7
Good morning
Thanks for using our forum
Hi Danny Herremans  my name is Johnnatan and I am part of the Small business Support community. In order to solve your problem follow these steps.
1. Go Firewall>General>Disable “Block WAN Request”
2. Go Firewall>General>Enable ”Remote Management”
3. Go VPN>VPN Pass Through>Verify all option be “enable”
4. In your  internal network  1 try using a  different address instead of  192.9.212.1 use a private network, in the range 192.168.x.x.
5. Create these two firewall rules in your computer
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=4&app=search&vw=1&articleid=2922
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
