03-13-2015 04:30 AM
Hi folks.
Just needing to find out how to implement static routing in my router. I can't seem to get it to work.
I have an internal server that I want all of my requests to go to, and it has an internal IP of 192.168.1.7. This router is 192.168.1.1, so it's pretty straight forward. So I thought. Also, can I break up various services to point to different machines? Such as:
Machine | Ports |
192.168.1.21 | 80, 443 |
192.168.1.7 | 25, 53, 110, 143, 995, 587 |
Firmware is 1.0.5.4
Any advice appreciated.
Cheers
Solved! Go to Solution.
03-14-2015 12:17 PM
OK, I'm blind. Thanks for the eye on that one. Everything is working now.
Thank you
03-14-2015 01:21 PM
I'm glad everything is working for you.
Please remember to mark an answer as correct if it was helpful to you so that other members can benefit from it.
Keep posting any other questions you may have.
