03-20-2016 04:37 PM
So I have RV320 and I'm trying to get my VPN working. I'm running the latest firmware. The way I set up the VPN is I went under VPN, Client To Gateway, then configured an "Easy VPN" connection type. I gave the tunnel a name, enabled it, setup a password, selected WAN1 interface (double checked that it was the one that was connected) , checked the Enable box and tried but Full Tunnel and Split Tunnel modes with the same result.
On the remote PC I installed Cisco Systems VPN Client Version 5.0.07.0440, gave it a name, put in the host, checked "Group Authentication" and put in the name and password (the tunnel name and password from the above step)
When I click the connect button on the client it thinks for a little while then I get "Secure VPN Connection terminated locally by the Client. Reason 412:The remote peer is no longer responding.
In the RV320 log I see a message in the log that says "packet from 192.168.1.254:500: [Tunnel Authorize Fail] no connection has been authorized with policy=PSK+AGGRESSIVE+XAUTHPSK+XAUTHSERVER"
ignore the IP address but you get the idea from the rest of the message
Any help would be extremely appreciated, I've been pulling my hair out on this, thank you, George
04-01-2017 11:09 AM
So the problem was with my ISP, they were at least somewhat blocking the port. The only way I was able to get it to work was to purchase a static IP from them because they don't block any ports with their static IP addresses
04-01-2017 11:35 AM
Thanks. I will keep this in mind. I am planning to have a support session with Cisco on Monday (RV320 still under warranty).
