08-25-2012 09:41 AM
I purchased a RV042G but the documentation doesn't make any reference that this router supports Mac OSX 10.8 or any other OSX version.
Does Mac OSX VPN client work with RV042G routers?
I appreciate any reply.
Solved! Go to Solution.
08-25-2012 09:47 AM
Hi Marcos, yes, for PPTP. The IPsec built in does not work by default as it is the "same" as the Cisco VPN 5.x.
-Tom
Please rate helpful posts
08-25-2012 09:47 AM
-Tom
08-25-2012 09:51 AM
Tom,
Is there a third party VPN client for MAC that can be used for this router? Like Open VPN?
Marcos
08-25-2012 09:54 AM
Ipsecuritas
-Tom
08-25-2012 09:58 AM
Thank you. I will check it out!
