Exempting websites from URL filter
racetalker1320
                   Using an ISA500 series router with URL filtering enabled.  I have a website that I would like to increase transmission speed on as it is dropping off at times.  The STARPARTS application with Chrysler appears to need all the help it can get to stay as a stable connection.  My thought was to setup a wild card exemption on all sites that included *.chrysler.* to try and improve response.  My thought process being that this high bandwidth consuming application would benefit from an unfettered access to the internet.
     So, that being said, can I exempt particular URL's from filtering and increase the response speed?
Sincerely,
John Odoj
mpyhala
Level 7
Level 7
John,
You can "Whitelist" a URL or URL Keyword by adding it to the Policy Profile. If it is not getting blocked already then it will have no effect. If it is getting blocked, it will unblock the URL or URL with that keyword. I don't think there is a way to speed up access to any given website.
- Marty
