FTP Passive Port Range Fowarding
msavard99
Im using vsftpd on a Linux Server and I need to forward a port range to this server (passive mode).
I can do it with any of the other routers I have but not with the RV220w.
I created a custom service with a start and finish range, but there is no place to enter a range under the Port Fowarding tab like I have with the other routers.
Im using the latest firmware by the way.
Any tips ?
Thank you
Mehdi Boukraa
Hi ,
Can you try please to do Access rules instead of Port forwarding. under firewall --> access Rules
from WAN to LAN | always allow | Choose your service | Source = any | Dnat = Local IP server
Enable rule
Please let me know after your testing
Please rate this port or marked as answered to help other Cisco Customers
thanks
Mehdi
I tried that already, I get "Disconnected from server: ECONNABORTED - Connection aborted" from my client (FileZilla).
The server runs perfectly in DMZ or behind the RV220w (local) btw.
I dont understand why Cisco has to make things so different. Even DD-WRT is more straightforward.
Thanks for your time btw.
