03-07-2019 03:59 PM
Previously I used RV082 that has vlan ids for each port. I could specify a different vlan2 to separate the port from all other ports that were associated with vlan1. All wired computers were connected to port1-port7 via switches or directly connected to the router. All wireless routers were connected to a switch that connected to port8 of the router.
RV340 seems very different from RV0xx.
How can I achive this on RV340?
Thank you for any help.
解決済! 解決策の投稿を見る。
03-08-2019 12:45 PM
Now, you need create a access rule on your RV340.
Step 1. Log in to the web configuration utility, and choose Firewall>Access Rules. The Access Rules page opens:
Create a rule with actione is DENY
rule_1
action = deny
service = all
source = vlan 1
destionation = vlan 2
time = aways
rule_2
action = deny
service = all
source = vlan 2
destionation = vlan 1
time = aways
check it if your have any doubts: https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4286-access-rules-configuration-on-rv320-and-rv325-vpn-routers.html
03-07-2019 04:12 PM
Hi @swu2019 ,
Check this link, maybe can help you:
Remember to mark the correct answers as solved, since that helps other users with similar doubts.
03-07-2019 04:17 PM 03-07-2019 04:18 PM 更新
You will need two dhcp scope for it, like;
vlan lan: 192.168.1.0/24
vlaan wireless: 192.168.2.0/24
set ip address as default gateway:
vlan lan: 192.168.1.1/24
vlan wireless: 192.168.2.1/24
create two vlan on your RV340
Go to tab page: lan > vlan settins > create two vlans
vlan 10(lan): ip address 192.168.1.1
vlan 20(wirelesS): ip address 192.168.2.1
Now, just associate it each vlan for specific port that you need.
03-08-2019 10:34 AM
Hi Jaderson,
Thank you for your input. I don't know how to associate a port to a vlan.
Should I specify untagged to the belonging vlan and exclude to another vlan?
I am confused about those terms. We don't have any vlan aware switches.
Shangwu
03-08-2019 10:44 AM 03-08-2019 10:49 AM 更新
Below a simple screen that can help you.
Select vlan x port and change configuration from tagged to untagged apply configurations and test your new config.
For exemple,
port 1 will be a device like DESKTOP > vlan 10 untagged and others vlan can be excluded.
port 2 will be a device like SWITCH > vlan 1 untagged and others vlan must be tagged (but on this switch you will need set his port as trunk).
03-08-2019 11:06 AM
03-08-2019 11:18 AM
03-08-2019 12:41 PM
After I restarted the wireless router on vlan2, devices on vlan2 can connect to internet now. But it still can ping devices on the vlan1 even though I set port2 as exclude from vlan1. Any idea?
03-08-2019 12:45 PM
rule_1
action = deny
service = all
source = vlan 1
time = aways
rule_2
action = deny
service = all
source = vlan 2
time = aways
03-08-2019 12:56 PM
03-08-2019 12:57 PM
Great,
good lucky in your next steps.
01-22-2020 01:05 PM
I just had to configure an isolated VLAN, applied them rules and boom job done :)
Thank you for the info :)
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
