How to add OpenVPN to RV340
sannjas1984
Hi!
Is there any possibility to add OpenVPN to RV340?
Thanks for answer.
balaji.bandi
If you looking Open VPN Server integrated into RV - i have seen one post RV3XX series, that should work for you also.
https://supportforums.cisco.com/sites/default/files/attachments/discussion/cisco_rv325_openvpn_initial_config.docx
BB
I don't have that drop-down item in the Certificate Generator. I also don't have OpenVPN server under vpn menu.
Did you ever figure this out? I'm also trying to set up an OpenVPN, on my RV340, but the (VPN) config is significantly different from the RV325.
@balaji.bandi Any pointers on how to apply the (aforementioned) RV325 config to the RV34x series?
Its not supported. Only the 200 and 100 series support openvpn.
