How to enable ipv6 dhcpv6-pd on rv130
alexlei262099
We are using rv130 to connect internet.
IPS offering internet connection via PPPOEv6 and IPV6 address.
WAN port can receive IPv4 and IPv6 address.
How can I config DHCPv6-pd ,so that on of my server on LAN can assign IPV6 address from ISP.
marce1000
 - Probably not supported the data sheet (https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-738909.html) , lists the following ipv6-features only :
IPv6
●  Dual-stack IPv4 and IPv6
●  6to4 tunneling
●  Stateless address auto-configuration
●  DHCPv6 Server for IPv6 Clients on LAN
●  DHCP v6 client for WAN connectivity
●  Internet Control Message Protocol (ICMP) v6
●  Static IPv6 Routing
●  Dynamic IPv6 Routing with RIPng
So. which product support DHCPv6-pd?
 - My initial reply could be incorrect , have a look at this guide :
            https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv130w/admin_guide/en/rv130w_admin_en.pdf
  Look for  'Prefix Delegation' with  find in your browser and view the concerned paragraphs completely. Check if this can provide more insights.
 M.
Oh, I found it.
Sadly. My ISP provide IPv6 after PPOE dialup.  and the option only affects WAN connection type is DHCPv6 mode.
When I set IPv6 wan DHCPv6 mode and Prefix Delegation enabled. WAN port can not get IPv6 address from ISP.
When I set IPv6 wan mode PPOE IPv6, then WAN port can get IPv6 address from ISP. but router can not prefix delegation  IPv6 addresses to LAN network.
I need is after PPOE dialup , WAN port be assigned from ISP, and  prefix delegation to my LAN.
I can not do that both.  I remember rv130 support it some years before.
