04-08-2012 01:30 PM
i'm using an rv220W and i whant to know if is it possible to assign vpn traffic to a vlan when i setup an ipsec tunnel?
or is there mybe another solution?
example:
Im using different vlans on my rv220W.
Vlan 10: engineers (ex: 192.168.1.0/27) no intervlan routing
Vlan20: sales (ex: 10.0.123.0/24) no intervlan routing
This is what i need:
- An engineer is on the road and when he makes a ipsec vpn connection => assignd to the vlan "engineers" so he can access the server/pc's in that vlan.
and when someone from the sales group starts a vpn connection he needs to be in the vlan "sales" so he can access his pc/data,...
Dimitri
04-10-2012 02:58 PM
Hello Dimitri,
What is the VPN client that you are using here? Did you setup a Quick VPN connection or did you setup an IKE/IPSec policy?
Wesley S
04-11-2012 12:25 AM
Hi Wesley,
the RV220W is the gateway and i will use my laptop with the application "cisco quick vpn" to connect to the rv220W
so i need to setup an ike/ipsec policy i guess?
Thanks!
Dimitri
04-11-2012 07:18 AM
Dimitri B,
No the QuickVPN feature allows you to only configure the remote management settings and create a QVPN user. These settings automatically build the rest of the configuration for that VPN.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
04-15-2012 05:14 AM
but can a vpn user then communicate with a device in a specific vlan? our is that not possible?
11-23-2012 10:24 AM
not in time, but...
solution:
username PC1 password 0 !encrypted!
username PC2 password 0 !encrypted!
vpdn-group DEFAULT
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 5
vpdn-group PC1
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname PC1.DOMAIN.COM
local name PC1
vpdn-group PC2
accept-dialin
protocol l2tp
virtual-template 2
terminate-from hostname PC2.DOMAIN.COM
local name PC2
interface Virtual-Template1
ip unnumbered Vlan1
interface Virtual-Template2
ip unnumbered Vlan2
interface Virtual-Template5
ip unnumbered Vlan5
11-23-2012 01:13 PM
Dimitri, I have exactly the same requirement. Did you ever find a solution?
Andrey, the RV220W doesn't support running scripts like enterprise routers/switches as far as I know.
11-23-2012 01:43 PM
pptp should permit the intervlan communication. you won't be able to 'directly connect' to that one specific subnet but you will be able to communicate across a vlan as you wish... and the router supports inter-vlan acl so you may limit traffic as you wish.
-Tom
Please rate helpful posts
11-23-2012 04:42 PM
Thanks Tom. Is IPSec not an option at all on the RV220W for this particular requirement?
Of course I haven't verified it for myself but reading this sort of thing on Wikipedia doesn't inspire confidence: "PPTP is (as of Oct 2012) considered cryptographically broken and its use is no longer recommended by Microsoft."
11-23-2012 06:49 PM
Historically your statement is true, the IPsec wouldn't be an option on this unit. You may try to make a LAN to LAN access rule in the attempt to make it work, since the LAN to LAN rules are a new addition, it may work (I haven't tested it for this purpose yet).
-Tom
11-27-2012 07:56 AM
It's the MS PPTP implementation that's broken, not PPTP itself.
See
11-24-2012 01:14 PM
Richard Iemand:
Richard, really? Give me a link please!
And what type encryption i can use for security?
(Sorry my English)
11-24-2012 01:51 PM
Another option is the SSL vpn, this can be full tunnel or split tunnel. The router supports 5 SSL connections.
-Tom
11-26-2012 05:45 AM
Hi Thomas,
i dont think that the ssl vpn is a solution.
for example you cant add 1 ssl connection in vlan 10 and another in vlan 20.
greetz
Dimi
11-26-2012 05:38 AM
Hi Richard,
did not found a solution... do you?
