LAN DHCP - Cisco RV042G
germanBLD86
Hi! i recently bought a Cisco RV042G to replace one E1200 and support
dual wan.
I spend the money just to be amazed by the fact that the DHCP in the LAN
part only support Class C IP address and 50 clients.... seriously?
I mean, even the E1200 doesn't THAT limitations. Please tell me that it
can be fixed with a firmware upgrade.
Ami Xiao
You can change the dhcp pool to support more than 50 client.
For Class C limitations, I think that's it even if you upgrade to latest version.
Ami Xiao
germanBLD86
Thanks for your reply!
Don't you love it?. In the era of open-source, Cisco is config-closed.
I'm gonna have to put one Mikrotik in the lan just to offer DHCP in the range of IP that i want. When the Manager ask why, my answer it's gonna be: "Just Cisco's things".
When i read that Cisco is firing people, i assumed that they will conserve the smartest ones...but not apparently
