12-21-2010 01:15 PM
My Linksys WRP400 router has stopped working :-(
Symptoms:
- power led blinks red and orange
- phone led 1 and 2 light green
- wifi connection not work
- ethernet LAN connection not work
- ethernet WAN connection not work
- router now work in bridge mode
- factory reset using Reset switch not work
- connected analogue phone not work
I try dump traffic using ngrep on LAN and WAN port but no packet comes from the router.
Thanks for your advice
01-31-2011 02:14 AM
I got the same problem. Anybody knows how can I solve
it?
12-11-2012 11:17 AM
Even though this is an old post, the above symptoms are the exact ones i experience when my power supply stopped working. (Now on my third power supply).
After replacing power supply, router boots fine again and everything is working with no lost settings.
