Load balance issues with RV042
Franxoois
I have some issue to configure my RV042.
I have 8 voip phones and 10 pcs on my network. I used DHCP to attribute IP between 192.168.1.10 and 192.168.1.20 to the phones and over .100 to the PC. I want my phone to have their own connexion. My switch doesn't support VLAN
Here is a screeshot of my config
The phones use WAN2, the PCs use WAN1 except to send emails.
Everything seems ok. If I change the ip of my computer to 192.168.1.19 I can verify on the web that my public ip is know as the one of WAN2, and if I change for 192.168.1.115, my public IP is the same as WAN1.
Few days ago, I checked the web interface of my phones provider and I watched the public IPs of each of my phones. Some have the wan2 IP but other have wan1 IP.
I thought I forced my phone to use WAN2 internet connection ... so how would my phone providers know the wan1 public IP ?? Is there another thing I have to check or force to avoid my phone tu use WAN1 ??
Thanks in advance,
Franxoois
Franxoois
Up
Any advice or something I should learn or check ? Is this normal or known bug ?
Is there an easiesr way to do something like that ?
