09-09-2013 04:26 PM
I am trying to find the lowest cost Cisco router with option 66. I use the router in conjunction with spa50x phones and need to be able to have them config at boot up.
I was using the srp521. It was suggested to use the isa550, but that just got an EOL. Do any of the RV routers support it, I did not find it on a rv110 and I know its not on the rv042. It seems to me that this is a functionality that should be on a router aimed at a small business.
Sage
Solved! Go to Solution.
09-13-2013 01:52 AM
Sage
I was also looking for a replacement for the SRP521. I found this in the Admin Guide for the RV180:
You might also try the RV emulators here, https://supportforums.cisco.com/community/netpro/small-business/onlinedemos.
Stephen
09-12-2013 07:48 AM
Dear Sage,
Thank you for reaching the Small Business Support Community.
Unfortunately none of the Small Business routers were intended to provide DHCP option 66 for IP Phones configuration via TFTF server. I suggest you to look for a enterprise device for that matter, like an ASA for example, and you can also inquire about a low cost option from their community support forum.
My job role in Cisco, among several, is to identify business opportunities and product enhancements for the Small Business products so I am definitely going to suggest this option 66 feature for future firmware releases.
Please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
09-12-2013 07:58 AM
Dear Sage,
I apologize for the discrepancy between my previous email and this one. I was checking on a RV320, and I found DHCP option 66, please check on the below link for its emulator;
https://www.cisco.com/assets/sol/sb/RV320/default.htm
I am sorry I did not noticed it before and again, please let me know if there is anything else I may assist you with.
Thank you,
09-13-2013 01:52 AM
Sage
Stephen
09-13-2013 11:41 AM
Check out what step 4 says on page 38
STEP 4 Click Save. You must then specify the MAC address of the clients that will be
downloading files and the filename of the configuration file they need to
download.
This does not look like its a good replacement. Have you actually tried this or are you just looking at the docs?
09-13-2013 06:44 PM
Just trolling the docs looking for routers that have Option 66 before ordering some to try.
Step 4 does looks to be superfluous as it seems to replicate a component function of the tftp server. A question for our Cisco rep to explain.
