Maximum number of active/connect Clients - RV 340W
JoelOrtiz59057
Hi team,
Somebody knows the maximum number of active/connect clients from the RV 340 SMB Router?.
I´ve been searching in data sheet and other documents but, nothing. Thanks for your support.
J.
sunilson
Hi JoelOrtiz59057,
My name is Sunil Soni from Small Business TAC team.
Please be informed that Cisco RV340W can support upto 50 users on 2.4 Ghz and 124 users on 5 Ghz frequency band and these are the Recommended user list.
For more information you may refer the datasheet of RV340W router.
https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-742350.html.
You may contact Cisco Support Frontline Phone Number: 000-800-040-1521
Cisco Support Worldwide Contacts:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
to get a new Service request opened and one of the available engineer will be happy to assist you.
Thanks and Regards,
Sunil Soni
Small Business TAC
6 Replies 6
balaji.bandi
active/connect Clients - Can you please clarify  in terms of VPN Client termination or  Lan Network ?
BB
Hi!,
I refer to wireless clients, how many active/connect clients support the device.
thanks!
Hi ,
My name is Akash Sharma and I am part of cisco SMB team .Please find the answer for your query .
RV 340W can support upto 50 concurrent WLAN clients .
Please find the below link of product specification and you can find the required answer under wireless option.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5621-product-specifications-of-the-rv340w-dual-wan-gigabit-vpn-ro.html
wrong answer akshar2.
Login to admin console -->Wireless-->Basic Settings-->2.4ghz you can setup up to 50 clients / 5ghz you can setup up to 124 clients (Firmware Version: 1.0.03.17)
Thanks akashar2!
sunilson
Hi JoelOrtiz59057,
Thanks and Regards,
Sunil Soni
Small Business TAC
