04-16-2019 04:29 AM
We have an RV340W on which we want to configure multiple VPNs.
In itself this is not the problem but now it comes.
I would like to set up 2 VPNs to the same Remote endpoint and the same Remote Identifier.
But when I try I get the message:
WAN interface setting is repeat with connection: XXXXX
The combination of 'Local WAN Interface', 'Remote Endpoint', 'Local Identifier' and 'Remote identifier' should be unique.
So what I am trying:
VPN 1
Interface: WAN1
Remote Endpoint static: 1.1.1.1
Local Group Setup
Local identifier type: Local WAN IP
Local identifier: 2.2.2.2
Local ip type: Subnet
IP Address: 10.10.1.0
Subnet Mask: 255.255.255.128
Remote Group Setup:
Remote identifier Type: Remote WAN IP
Remote identifier: 1.1.1.1
Remote ip Type: Subnet
Ip adress: 10.100.40.0
Subnet mask: 255.255.255.0
VPN2:
Interface: WAN1
Local Group Setup
IP Address: 10.10.1.128
Subnet Mask: 255.255.255.240
Remote Group Setup:
Ip adress: 10.100.42.0
The only difference is in the local and remote subnet.
Is there someone here who has a solution for this?
Thanks in advance!
04-25-2019 05:35 AM
Is there anyone who has a solution for this? Or is it just not possible?
04-25-2019 08:08 PM
On the RV340 Series routers, starting with firmware version 1.0.2.16, you can do this with IP Address Groups. In System Configuration > IP Address Groups, you can create a LocalGroup for the local subnets ( add subnets 10.10.1.0/255.255.255.128 and 10.10.1.128/255.255.255.240) and a RemoteGroup for the remote subnets (add subnets 10.100.40.0/255.255.255.0 and 10.100.42.0/255.255.255.0).
Then in Site-to-Site VPN, you can use:
Local IP Type: IP Group
IP Group: LocalGroup
Remote IP Type: IP Group
IP Group: RemoteGroup
Let me know if you have any questions regarding this.
