Problems with RV180
drjoliverdaly
Dear all,
1. Latest firmware update has made it impossible to access Lap IP address settings, it just keeps loading and never shows the LAN ip configuration screen. This is despite rebooting the router multiple times. I am unwilling to go back to the previous firmware update for the router because of the security vulnerabilities you’ve published.
2. It is impossible to set daylight savings time in the Southern Hemisphere because of the requirement in the DST date requirements that the end date is after the start date. In the Southern Hemisphere, day light saving starts in October and finishes in April of the next year.
 - This question has been asked before without any response or recognition of the issue
 - Please do not answer this question by going through the time setting instructions.
3. I'm also quite unhappy with the level of support from Cisco. There appears to be no other way to request support about their small business products other than through this forum.
Thanks in anticipation.
cmamine2cisco
You should press the button of reset fiew moment and let it, it will restart again and you can configurat it
