04-25-2012 11:57 AM
we have a router SRP 527. Some of our cutomers are thinking about buying this and the SRP 547. The idea being that it is a router with QoS together with a ATA of 2 or 4 lines. The question is: Can we provision the SRP using the SPC tool for the SPA 112?. If not does it has its own spc?, any pointer to specific documentation would be really apprecited.
Thank you, Diego Betancor
Solved! Go to Solution.
04-25-2012 01:40 PM
I used the profile compiler (SPC) tool of WRP400 to build an XML provisioning file for SP520 and SRP520-U. Probably is not the best way but it works.
I don't found a specific SPC for SRP.
Regards.
04-25-2012 01:40 PM
Regards.
05-04-2012 10:15 AM
Thank you Daniele, it works.
Probably it would work as well for a spa122 or 2102 if you take away the IP and DNS stuff as the commands are more or less the same. I think the different versions of spc, what they do is just to check the comands.
