Router for multiple public IP addresses go into LAN
chicagotech
The client has a Cisco RVS4000. There are 3 Internet devices need to be accessed from the outside and will use one public IP for one device. I don't see any options to setup on Cisco RVS4000 to do 3 NATs. If Cisco RVS4000 doesn't work in this situation, which router will do?
Te-Kai Liu
Level 7
Level 7
RV042G, RV180, RV180W, and RV220W all support 1-to-1 NAT, which allows multiple public IP addresses to be mapped to private IP addresses in the LAN.
Te-Kai Liu
Level 7
Level 7
