Router on stick? RV345+SG200
ManoaChris
Beginner
Beginner
I am trying to use multiple VLANs with an RV345 router and SG200 50-port switch. The VLANs themselves and internet access are working great, but I cannot ping from one VLAN to the other.
Details:
  • InterVLAN Routing is selected for all VLANs on the RV345 VLAN settings page
  • VLANs are correctly tagged on the SG200, and intra-VLAN and internet access work fine
  • hosts on different VLANs connected directly to RV345 ports *can* connect
  • hosts on different VLANs connected to SG200 ports *cannot* conenct
  • tried: changing SG200 VLAN interface settings to disable ingress filtering and admit all frame types
  • tried: using VLANs 2 and 3 (based on reports of VLAN1 problems on RV34x routers
  • tried: disabling the firewall on the RV345
  • tried: adding static routes on the RV345
Any suggestions?
ManoaChris
Beginner
Beginner
Unfortunately, I have been unable to resolve this. Although the SG200 provides basic VLAN support, there does not appear to be  a way to implement inter-VLAN routing, at least with an RV345 router. I wonder if the issue is that the SG200 can only have a single IP address in a single VLAN, and so support is limited to preserving and forwarding VLAN tags onto the router.
Anyway, I purchased an SG500, enabled layer 3, and inter-VLAN routing is working fine now.
12 Replies 12
balaji.bandi
VIP Community Legend VIP Community Legend
Where is this VLAN Layer 3 configured on  SG200 or RV 345 ?
BB
Thanks - SG200 isn't layer 3 capable, so all it is doing is mapping and supporting tags on the ports. RV345 has the VLANs configured with cross-VLAN routing enabled (and working as long as it doesn't touch the SG200).
Appolgies, i was in impression SMB switches do Layer3, but SG200 not,
if RV doing all VLAN Interface and routing, you need to Look Inter-vlan routng document which you might have read.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/1393-Inter-VLAN-Routing-with-Targeted-ACL-Restrictions.html
check this thread :
https://community.cisco.com/t5/small-business-routers/rv345-static-routing-inter-vlans-not-working/td-p/4136400
Still an issue, if any new firmware available upgrade and test please.
BB
Thanks for the suggestions - some thoughts:
1.Yes, I saw that documentation previously. Basically you just need to check the box for interVLAN routing. I have no ACLs, and interVLAN works on the RV345 ports, but not passing through the SG200.
2. Hadn't seen the thread you shared, but reading through it, issue seemed to be a misunderstanding of tagging -- consistent with the advice given, I have my trunks correctly tagged (untagged for native VLAN, tagged for others).
3. I'm already on the latest firmware for both devices.
I suspect I am missing some other configuration requirement on the SG200, but it doesn't seem to be obvious.
balaji.bandi
just input may help you ( i may be not expert of SGswitches )
All Trunk ports must have tagged vlan added to them including the uplink going to the router RV.
BB
Yes, the trunks have all VLANs tagged (except for the native VLAN which is untagged) on both the SG200 and corresponding ports on the RV345.
Just for reference :
https://www.megajason.com/2016/03/03/how-to-set-up-vlans-when-you-dont-understand-vlans/
can you post show run from SG200 to look.
BB
No SSH support on SG200, but the web UI does allow download of a config file:
config-file-header
switch305808
v1.4.9.4 / R800_NIK_1_4_205_011
CLI v1.0
set system
file SSD indicator plaintext
port jumbo-frame
vlan database
vlan 2-3
exit
voice vlan state disabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
green-ethernet energy-detect
green-ethernet short-reach
hostname switch305808
ip http authentication aaa login-authentication http none
no passwords complexity enable
username cisco password encrypted 36ef150d24bf8bfd5a5833b1179a2c22ef0be893 privilege 15
snmp-server server
ip http timeout-policy 0
no ip http secure-server
ip domain timeout 1
ip domain polling-interval 4
interface vlan 2
name "VLAN2"
interface vlan 3
name "VLAN3"
interface gigabitethernet1
switchport mode general
switchport general allowed vlan add 2 tagged
switchport general ingress-filtering disable
lldp med disable
interface gigabitethernet2
lldp med disable
interface gigabitethernet3
lldp med disable
interface gigabitethernet4
switchport trunk allowed vlan add 2
lldp med disable
interface gigabitethernet5
lldp med disable
interface gigabitethernet6
lldp med disable
interface gigabitethernet7
lldp med disable
interface gigabitethernet8
lldp med disable
interface gigabitethernet9
lldp med disable
interface gigabitethernet10
channel-group 3 mode auto
lldp med disable
interface gigabitethernet11
channel-group 2 mode auto
lldp med disable
interface gigabitethernet12
lldp med disable
interface gigabitethernet13
lldp med disable
interface gigabitethernet14
lacp timeout short
channel-group 1 mode auto
qos cos 3
lldp med disable
interface gigabitethernet15
lldp med disable
interface gigabitethernet16
lldp med disable
interface gigabitethernet17
lldp med disable
interface gigabitethernet18
lldp med disable
interface gigabitethernet19
lldp med disable
interface gigabitethernet20
lldp med disable
interface gigabitethernet21
lldp med disable
interface gigabitethernet22
lldp med disable
interface gigabitethernet23
lldp med disable
interface gigabitethernet24
lldp med disable
interface gigabitethernet25
switchport general allowed vlan add 2 untagged
switchport general pvid 2
lldp med disable
switchport default-vlan tagged
interface gigabitethernet26
lldp med disable
interface gigabitethernet27
lldp med disable
interface gigabitethernet28
lldp med disable
interface gigabitethernet29
lldp med disable
interface gigabitethernet30
lldp med disable
interface gigabitethernet31
lldp med disable
interface gigabitethernet32
lldp med disable
interface gigabitethernet33
lldp med disable
interface gigabitethernet34
lldp med disable
interface gigabitethernet35
lldp med disable
interface gigabitethernet36
lldp med disable
interface gigabitethernet37
lldp med disable
interface gigabitethernet38
lacp timeout short
qos cos 3
lldp med disable
interface gigabitethernet39
lldp med disable
interface gigabitethernet40
lldp med disable
interface gigabitethernet41
lldp med disable
interface gigabitethernet42
lldp med disable
interface gigabitethernet43
lldp med disable
interface gigabitethernet44
lldp med disable
interface gigabitethernet45
lldp med disable
interface gigabitethernet46
lldp med disable
interface gigabitethernet47
lldp med disable
interface gigabitethernet48
lldp med disable
interface gigabitethernet49
lacp timeout short
channel-group 4 mode on
qos cos 3
lldp med disable
interface gigabitethernet50
lacp timeout short
qos cos 3
lldp med disable
interface Port-channel1
flowcontrol on
description workstation
qos cos 3
switchport general allowed vlan add 2-3 tagged
interface Port-channel2
flowcontrol auto
description NAS
interface Port-channel3
flowcontrol on
description DVR
switchport general allowed vlan add 3 tagged
interface Port-channel4
flowcontrol auto
description LAG4
qos cos 3
switchport trunk allowed vlan add 2-3
exit
I looked at this link:
He suggests that the trunk ports between switches be set up with all VLANs tagged (and nothing untagged). Such a configuration isn't possible on either the RV345 or the SG200 -- each port must have at least one VLAN untagged (native) or in the words of the Cisco web error message must be a member of at least one VLAN.
balaji.bandi
thank you, can you please point me which interface connected to RV ?
BB
Yes, it's LAG4 (which is an aggregate of the uplink ports 49+50).  FWIW, I also tried it with the LAG removed but saw same issue.
ManoaChris
Beginner
Beginner
Recognize Your Peers
