router with 100mbps downstream
hendrikhoppe
hi,
I'm looking for a new router because my old RV082 isn't able anymore to handle the speed of my new ISP (100 down / 10 up).
Do you know which equivalent router of cisco is able to handle this?
would be great if it had the same capabilities and would be rack mountable…
thanks
5 Replies 5
Leo Laohoo
Cisco 1941.
Is there also a more budget one?
There are new router models for high speed internet, in the small business line of products.
Could you please tell me which model has a faster connection. I found the spec sheets are not self explanable…
The RV042G model would be a good fit if you don't need the 4 extra ports. The SA540 model would be the next dual WAN router that has most of the features of the RV0XX series (and a lot more extras) including the 8 lan ports. There aren't too many options in the way of dual wan routers.
If you don't need dual wan capability, the RV180 and RV220W router should suffice but have 4 lan ports.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
