RV042, 082, 016 with SX300/500 switch open discussion
Tom Watts
Hi all, this is an open topic to interopate Cisco small business RV042, RV082 and RV016 in conjunction with the Cisco Small Business SX300 and SX500 switches. Feel free to ask questions in relationship to the RV0XX routers and SX300/500 series switches to optimize your scenario!
Don't forget to check out the small business blog
http://blogs.cisco.com/smallbusiness/
The RV0XX series does not support 802.1q VLAN. To overcome this limitation, we will employee the SX300/500 switch. This topic is also applicable for any other router which does not support 802.1q subinterfaces or VLAN tagging (so long as you know how to operate that router).  In addition, the RV0XX supports only 1 DHCP scope
The dependencies are as follows-
  • Cisco SX300 or SX500 in layer 3 mode
  • RV042, RV082 or RV016 with internet connection
Here is how to configure basic connectivity to make the foundation of your network.
  • Once you have put your switch in to layer 3 mode, change the VLAN 1 IP address to a static IP address, in this case, 192.168.2.254
  • Create a second VLAN, in this case, we create VLAN 2 with the name Internet
  • Assign a static IP address to the second VLAN you've created, in this case we will be using 192.168.3.254 on a /24 mask for the VLAN 2
  • Assign the switch ports you wish to be a member of the VLAN you created, in this case, I have assigned port 2 to VLAN 2 untagged
  • Enable the DHCP server on the switch
  • Create a DHCP pool, in this case, we will be creating the pool to correlate to VLAN 2 on the 192.168.3.x subnet
  • Log in to your RV0XX router and enable multiple subnet
  • Define your multiple subnet, in this example, 192.168.3.0 network with /24 mask
  • Create a static route to direct traffic to 192.168.3.0 subnet to the VLAN 1 gateway, on this case it is 192.168.2.254
  • Create a second IP route to direct traffic to the 192.168.2.to the VLAN 2 gateway, on this case it is 192.168.3.254
  • Remember we configured port 2 as VLAN 3 untagged. Move a connection to port 2 and verify you receive a proper DHCP address and confirm the internet works
Keywords-
RV042, RV082, RV016, SF300, SG300, SF500, SG500, layer 3, router, switch, vlan, SVI, ACL, routing, Cisco, Small Business, help, assistance, how to, how do I, do it yourself,  blog, discussion, forum, post,
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
23 Replies 23
Tom Watts
please delete this post
Tom,
Where is the part about the access control lists? It is gone, I guess due to the new UI of supportforums?
I'm thinking you're right.
It looks like the only thing left there is an empty message by me. Another interesting thing (and may be my lack of familiarity), since I created this without a specific forum, I do not really see it any where yet.
josjanssen
Community Member
Tom,
I do own a RV042G, SG300-10,SG200-26p.
No network experience, this are my first steps in vlan setup.
I made 3 Vlan's : Vlan1 default, Vlan2 and Vlan3
I have made the steps according the pictures,only diferent ip numbers
Now i have inter net on vlan1 on the sg300/200 .
For Vlan 2 and 3 i do get dhcp and can communicate between the 2 switches,i can also ping from vlan 2 to vlan1 or the router and vica versa, but dont get internet connection to it.
I did put the Fa9 uplink set as trunk to the router, what do i miss?
Jos
Hi Jos, it sounds to me you are missing static routes on the RV042G router to point back to the switch VLAN IP addresses.
Please reference the 2nd picture from the BOTTOM for the static routes. Also make sure the multiple subnet feature is enabled and specify the subnet IP addresses you are using.
Hi Tom,
Thank for comming back.
I enabled 2 subnets 192.168.20.1/24 and 192.168.30.1/24
static routes:
192.168.20.0 -196.168.1.254 hop1 /24
192.168.1.0 -196.168.20.254 hop1 /24
192.168.30.0 -196.168.1.254 hop1 /24
192.168.1.0-196.168.30.254 hop1  /24
Hope this gives the ansewrs.
Jos
Hi Jos, where does the 192.168.1.x subnet come from?
With your set up as it is present. I believe a default gateway on the switch is required because it does not have direct connect route since the switch is unaware of the 192.168.1.x subnet?
You can try to set ip default gateway 192.168.1.254 assuming that is the router default IP interface.
If I'm wrong about the above, here is another possible scenario.
So let's say your router is 192.168.20.1 and one of your VLAN is 192.168.20.254 (this is the native connectivity). Your second VLAN is 192.168.30.254.
The routes would be something like
192.168.30.0 to 192.168.20.1 /24
192.168.20.0 to 192.168.30.254 /24
Hi Tom,
The static Ip's i have set on the switch are:
Vlan1 192.168.1.254/24
Vlan2 192.16820.254/24
Vlan3 192.168.30.254/24
Ip of the router is 192.168.1.1
Thought i did the routing right, but think now i miss understood it all pse advise
Jos
Okay, with this in mind, I am guessing you are interconnecting the devices on VLAN 1, 192.168.1.x network. That also means anything connecting on 192.168.1.x will work on the internet without issues.
I think your routes are right, they seem correct.
The computers you're testing with, what default gateway do they use per different VLAN?
Also, can you try to execute the command on the switch
config t
ip default-gateway 192.168.1.1
In theory the gateway command above should give an error "this already exist in the route table" or something like that.
Also please post command from the switch "show ip route".
Tom,
Default gateway for vlan1 is 192.168.1.1 all works fine on both switches.
For vlan2 default gateway gives 192.168.20.254
This are the routtes i have on the 300-10
IPv4 Static Routing Table
Destination IP PrefixPrefix LengthRoute TypeNext Hop Router IP AddressRoute OwnerMetricAdministrative distance
0.0.0.00Remote192.168.1.1Static11
192.168.1.024Local0.0.0.0Directly Connected
192.168.20.024Local0.0.0.0Directly Connected
192.168.30.024Local0.0.0.0Directly Connected
Edit...
 <td class="btnTD2" width="62" id="btnDelete_tdNode" '="" style="border-collapse: collapse; border-spacing: 0px; border: none; padding: 0px; margin: 0px; vertical-align: top; text-align: center; background-image: url(http://192.168.1.254/csd59e7132/kubrick/images/button.gif); height: 26px; line-height: 22px; background-position: -9px -90px; background-repeat: no-repeat no-repeat;">Delete
How can i get get the ip route of the switch, must i make a terminal "rs232" connection?
Hi Jos, if you want to use CLI without RS232, you can go to Security -> TCP UDP services and enable telnet.
Then you may telnet over the RJ45 connection.
The output provided is what was needed. Based off what you're telling me, there isn't a problem. If you want, we can do a quick teamviewer and see if we can see what is the problem.
Hi Tom,
Ok, how does teamviewer works?
Jos
Hi Jos, go to http://www.teamviewer.com/en/download/windows.aspx and download teamviewer 9. Install it, open it up. Once it is open, send me the meeting code and password via email at tmw0402@hotmail.com
Did send it
