RV042 and Exchange Activesync
CStark9829
We tried to turn on https on the router to enable quickVPN connections.  As soon as we did it broke Activesync for Exchange2010. It stated that the certificate does not match the site.  The cert that was showing up was the cert for the router.  Is there a way to turn on https on an RV042 and not break activesync?
Thanks in advance
jasbryan
Level 6
Level 6
Colt,
I take it this is a version 3 hardware. Remote management just has to be enabled for Qvpn to work. Since you are forwarding 443 internal to your exchange server. So under the firewall tab disable the HTTPS tab for remote management.
Qvpn will still work and so should Exchange.
hope this helps,
Jasbryan
I got caught up in some other things straightening out this network.  I am just now getting back to this so sorry for the delay in response. This is firmware version v4.0.0.07.  Remote Management is on and HTTPS is off and it does not work. Any other suggestions?
Thanks in advance,
Colt,
yes, i would upgrade to the latest firmware on the RV042. I think you are four firmware's behind.
http://www.cisco.com/cisco/software/type.html?mdfid=282414010&i=rs
I would upgrade in increments
Jasbryan
