RV042 issue remote management access
raszytko15
Installed on two RV042 links with adsl load balance, everything works fine, except that an error occurs during a time I can access the remote management via Web RV042 both the LAN and the WAN, only after a while when accessing the page appears to login, but when you enter your username and password the browser is trying to give an error, the connection to the internet works normal again and I can only access the remote management to disconnect and reconnect the RV042, but updated the firmware the error continues, my RV042 is:
RV042 V03
Firmware v4.1.1.01-sp
I changed the default https port (443), to other ports but the error continues, someone had this problem?
André Szytko
André Szytko
5 Replies 5
handoko wiyanto
Level 3
Level 3
hi there,
i can use google translate to try understanding your post. but i think its better for you to explain in english mate
regards,
paolo bevilacqua
Beside the language issue, this is the wrong forum, post in °small business - routers°. You can move your post using the actions panel on the right.
Moved.
André Szytko
André Szytko
If you are load balancing using two IPs, try binding https (protocol binding) to just one static IP.
I had already done that and it did not work.
André Szytko
André Szytko
