rv042 loose connection
taras.fyshka
i have Cisco rv042.
Firmware Version: v4.2.3.03
configured dual wan and load balance.
i`ve problem with Patton sn4639 BRI So VOIP Router, that every minute loose connection, and need te register again.... when it connected directly to modem everything work`s fine.
Any ideas how to fix it?
thank you
Hi Taras,
I think it should be SIP ALG option should be configured on the RV042
so please go to the webgui and open a hidden page
https://ip.address.of the.router/f_general_hidden.htm
and you can see the SIP ALG option
Please let me know after your testing
Mehdi
8 Replies 8
Mehdi Boukraa
Hi Taras,
As I understand you have Dual WAN and Load balancing , my question do you setup a protocol binding to bind the Voice traffic to go through only one WAN
with protocol binding you can dedicate WAN1 for example for voice Traffic
Protocol binding is working from LAN to WAN under protocol binding setting you have to choose the source IP range , you can have Range of IP for the phone
Destination 0.0.0.0 - 0.0.0.0  and select WAN 1 for example and enable it and save the configuration
thanks
Mehdi
Hi mboukraa,
thanks for reply, i`ve tryed to setup protocol binding, my gateway has ip 192.168.1.50 so i`ve made a rule: "All Traffic [TCP&UDP/1-65535]->192.168.1.50~192.168.1.50(178.250.46.69~178.250.46.85)WAN2[Enabled]"
don`t helps((
Hi Taras,
Jus tto be sure regarding the protocol binding configuration
the source IP should be the IP address of the phones not the gateway and destination IP let's test with 0.0.0.0 it means to any Public IP
Please can you confirm this configuration
Mehdi
sorry, i was intended voip router-gateway... my fail...
i`ve tryed to change the rule, patton voip router has ip 192.168.1.50 so it looks like "All Traffic [TCP&UDP/1-65535]->192.168.1.50~192.168.1.50(0.0.0.0~0.0.0.0)WAN2[Enabled]"
and problem still exist
thank you
Taras
Hi Taras,
Mehdi
Hi Mehdi,
tomorrow i will make more tests and let you now, but it seems that everything work`s fine now. thank you for help
best regards
Taras
Hi Taras,
Good :) ok let's test tomorrow and let me know
Please rate the post or marked as answered to help other Cisco Customers
Mehdi
Hi Mehdi,
looks like everything works fine and there are is no problems. thank you for help
best regards
Taras
