RV042 not blocking https forbidden domains
zaher.reda
I am trying to block a certain domain, i used "domain" and "domain.com" in the forbidden domains , but when people access the website as https://domain.com the website loads perfectly. Http is blocked however.
I tried to block "https://domain.com", but that didn't work.
What is the issue?
Dear Zaher ,
Check the Firewall Settings you will probably fid that you enabled the HTTPS to allow you to Remotely Login to the RV-042 using the WAN IP Address. Please review the below Image.
Please Rate Helpfull Posts.
M.Tag
Hello Mohamed,
This is already disabled.
I have firmware version: 1.3.13.02-tm by the way.
