RV042 remote admin question
Vowinc2011
I'm hoping this question has a simple answer that i'm overlooking.  One of our customers has to abide with some regulations and a security company has ran a scan on their network and reported vulnerabilities.  One of those vulnerabilities is in regards to port 443.  When going to their address remotely (i.e. https://dynamicname.dyndns.com), you are prompted for a login even though we specifically defined a port for remote admin (i.e. https://dynamicname.dyndns.com:XXXX).  I would think since we defined the port for remote admin then 443 wouldn't be able to access the router.  Is there a way to fix this?  We tried blocking just port 443 but that locked us out of the router for some reason.  Any feedback is greatly appreciated.
Te-Kai Liu
Level 7
Level 7
If port 443 is not used, you could consider forwarding port 443 to a LAN IP that is not used as a workaround to pass the security scan.
Which firmware are you using on RV042?
