RV042 v4.2.2.08 problem connecting to ISP with WAN Connection Type PPTP
richard.polasek
I have an issue with an RV042V3. It does not connect to my ISP with PPTP connection type and username 'comsulting/net@mmc.at' , pwd 6 digit alphanumeric.
Using the RVS4000 or the old RV082V2 with firmware 2.0.2.01-tm, the WAN PPTP connection works fine.
Unfortunately, the RV042 does not output any logging information about the PPTP dialin attempts to the ISP (if there are any).
Did anybody face the same issues?
Richard
shefweather
Works fine here using the windows client. What VPN client are you using?
Hi Jonathan,
thanks for the reply. I fear there is a misunderstanding.
I am not having troubles with the PPTP server functions of the RV042 but with the client functions.
My ISP services use PPTP to dialin to the internet instead of e.g. PPPoE.
This can be chosen in the WAN connection settings but does not seem to work!
Richard
